Forum: HoseHeads SprintCar Classifieds Forum (go)
Moderators: hosehead
Topic: Quality Used Racing Parts
ncraceparts
October 15, 2012 at 07:59:39 AM
This message was edited on October 15, 2012 at 08:03:37 AM by ncraceparts
Quality used racing parts featuring brands like Penske, Ohlins, The Joie of Seating, Butler, ATL, Brembo and much more. Complete list available at www.ncraceparts.com or call 800-739-0018.
Quarter Master Rear Motor Mounts $39.00
Oval Craft Breather Tank $15.00
Window Safety Net - Nylon Ribbon Rectangle $5.00
AFCO Motor Mounts $14.00
CV Products Gas Pedal Rod $19.00
The Joie of Seating Aluminum Containment Racing Seat $749.00
Butler Built Aluminum Containment Racing Seat $650.00
Thermal Control Products - SFI, Nomex Shifter Boot $20.00
Set of 4 Winters Chrome Wheel Locators for Wide 5 Hubs $49.00
Butler Built Full Containment Seat - Ex. Sprint Cup $375.00
Butler Built Full Containment Seat $350.00
18 Gallon Fuel Cell Bladder and Fuel Pickup $65.00
The Joie of Seating Full Containment Seat $550.00
Fine Thread Wheel Stud and Lug Nut Kit $23.00
Dry Sump Oil Tank $90.00
Lot of (6) A Frames $19.00
Lot of (15) Spring Rubbers $49.00
Lot of (10) Spring Rubbers $35.00
Lot of (12) Spring Rubbers $35.00
Fuel Cell Top Plate with Check Ball $125.00
Female Dry Break $69.00
Brembo Grand National Style Hats and Rotors $75.00
14 Gallon NASCAR Nationwide Series Fuel Cell $349.00
Appleton 2.0 Rack with Servo $299.00
Nelson Specialties Rev Control Box $29.00
Peterson 400 Series In-Line Oil Filter $65.00
NASCAR Approved Pit Helmet $35.00
(2) Ford Carter Fuel Pumps $75.00
Sponsorship Proposal Template, by RaceQuest $39.99
RaceQuest Pro - Custom Proposal Development $499.00
Turn-Key Racing Sponsorship Programs - eBook $19.99
RaceQuest Marketing Manager - Sponsorship Book $19.99
Turn-Key Racing Sponsorship Programs $19.99
Racing Sponsorship Proposal Template $19.99
Wilwood Master Cylinders $35.00
Ohlins Rebound Adjustable Shocks $175.00
Dynotech Drive Shaft with Yoke $45.00
(3) New Quarter Master Clutch Discs $89.00
(3) New 10 Spline Quarter Master Discs $79.00
5.5" Quarter Master PRO with Flywheel $349.00
Crane Cams HI-6RL Ignition with Rev Limiter and Mount $199.00
Quick Car Ignition Panel $20.00
Five Star Cold Air Box $65.00
Serpentine Crank Pulley $19.00
5.5" Quarter Master V-Drive Clutch with Reverse Ring Gear $299.00
Fuel Log $45.00
Oil Line Insulation $79.00
Carbon Fiber Brake Ducts - Sprint Cup Team $99.00
The Brake Man - Set of (4) Calipers $579.00
Brembo Grand National Hats and Rotors $75.00
Irvan-Smith Bump Steer Gauge $299.00
C&R Remote Oil Filter Mount with Fittings $65.00
Draco Front Springs - (8.75" Tall x 5.25 - 5.75 ID) - Many Rates $29.00
Draco Front Springs - (8.75" Tall x 5.25 - 5.75 ID) - Many Rates - 375 $29.00
Draco Front Springs - (8.75" Tall x 5.25 - 5.75 ID) - Many Rates - 400 $29.00
Draco Front Springs - (8.75" Tall x 5.25 - 5.75 ID) - Many Rates - 425 $29.00
Draco Front Springs - (8.75" Tall x 5.25 - 5.75 ID) - Many Rates - 450 $29.00
Eibach Rear Platinum Springs (12" Tall x 5" OD) $29.00
Eibach Rear Platinum Springs (12" Tall x 5" OD) - 400 $29.00
Eibach Rear Platinum Springs (12" Tall x 5" OD) - 540 $29.00
Eibach Rear Platinum Springs (12" Tall x 5" OD) - 550 $29.00
Eibach Rear Platinum Springs (12" Tall x 5" OD) - 560 $29.00
Eibach Rear Platinum Springs (12" Tall x 5" OD) - 600 $29.00
Eibach Front Springs (8.75" Tall x 5.75 OD) $29.00
Eibach Front Springs (8.75" Tall x 5.75 OD) - Many Rates - 400 lbs $29.00
Eibach Front Springs (8.75" Tall x 5.75 OD) - Many Rates - 475 $29.00
Eibach Front Springs (8.75" Tall x 5.75 OD) - Many Rates - 500 $29.00
Eibach Front Springs (8.75" Tall x 5.75 OD) - Many Rates - 575 $29.00
Eibach Front Springs (8.75" Tall x 5.75 OD) - Many Rates - 600 $29.00
Eibach Front Springs (8.75" Tall x 5.75 OD) - Many Rates - 650 $29.00
Eibach Front Springs (8.75" Tall x 5.75 OD) - Many Rates - 700 $29.00
Pair of Grand National Style Rear Drive Plate (5X5) $25.00
Grand National Front Hub with Accessories $35.00
Grand National Hub Kit $169.00
Grand National Rear Hub with Accessories $55.00
Grand National Style Hats $29.00
Winters Light Weight Wide 5 Hub $74.99
Winters Oil Bath Hub with New Angular Contact Bearings $99.00
Hyperco - Hypercoil Conventional Rear Springs (13" Tall X 5" OD) $29.00
Hyperco - Hypercoil Conventional Rear Springs (13" Tall X 5" OD) - 125 $29.00
Hyperco - Hypercoil Conventional Rear Springs (13" Tall X 5" OD) - 160 $29.00
Hyperco - Hypercoil Conventional Rear Springs (13" Tall X 5" OD) - 250 $29.00
Hyperco - Hypercoil Conventional Rear Springs (13" Tall X 5" OD) - 275 $29.00
Hyperco - Hypercoil Conventional Rear Springs (13" Tall X 5" OD) - 300 $29.00
Hyperco - Hypercoil Conventional Rear Springs (13" Tall X 5" OD) - 375 $29.00
Hyperco - Hypercoil Conventional Rear Springs (13" Tall X 5" OD) - 425 $29.00
Hyperco - Hypercoil Conventional Rear Springs (13" Tall X 5" OD) - 450 $29.00
Hyperco - Hypercoil Conventional Rear Springs (13" Tall X 5" OD) - 600 $29.00
Hyperco - Hypercoil Conventional Rear Springs (13" Tall X 5" OD) - 650 $29.00
Hyperco - Hypercoil Conventional Rear Springs (13" Tall X 5" OD) - 950 $29.00
Hyperco - Hypercoil Conventional Rear Springs (15" Tall X 5" OD) $29.00
Hyperco - Hypercoil Conventional Rear Springs (15" Tall X 5" OD) - 125 $29.00
Hyperco - Hypercoil Conventional Front Springs (8.75" Tall x 5.5 OD) $29.00
Hyperco - Hypercoil Conventional Front Springs (8.75" Tall x 5.5 OD) - 1050 $29.00
Hyperco - Hypercoil Conventional Front Springs (8.75" Tall x 5.5 OD) - 1075 $29.00
Hyperco - Hypercoil Conventional Front Springs (8.75" Tall x 5.5 OD) - 1350 $29.00
Hyperco - Hypercoil Conventional Front Springs (8.75" Tall x 5.5 OD) - 1400 $29.00
Hyperco - Hypercoil Conventional Front Springs (8.75" Tall x 5.5 OD) - 1450 $29.00
Hyperco - Hypercoil Conventional Front Springs (8.75" Tall x 5.5 OD) - 1482 $29.00
Hyperco - Hypercoil Conventional Front Springs (8.75" Tall x 5.5 OD) - 1600 $29.00
Hyperco - Hypercoil Conventional Front Springs (8.75" Tall x 5.5 OD) - 1782 $29.00
Hyperco - Hypercoil Conventional Front Springs (8.75" Tall x 5.5 OD) - 1784 $29.00
Hyperco - Hypercoil Conventional Front Springs (8.75" Tall x 5.5 OD) - 1900 $29.00
Hyperco - Hypercoil Conventional Front Springs (8.75" Tall x 5.5 OD) - 1975 $29.00
Hyperco - Hypercoil Conventional Front Springs (8.75" Tall x 5.5 OD) - 2130 $29.00
Hyperco - Hypercoil Conventional Front Springs (8.75" Tall x 5.5 OD) - 2150 $29.00
Hyperco - Hypercoil Conventional Front Springs (8.75" Tall x 5.5 OD) - 2200 $29.00
Hyperco - Hypercoil Conventional Front Springs (8.75" Tall x 5.5 OD) - 2300 $29.00
Hyperco - Hypercoil Conventional Front Springs (8.75" Tall x 5.5 OD) - 400 $29.00
Heat Shield, Floor Matting $25.00
Kevlar (2 hole) Brake Duct $15.00
NEW! Kevlar (1 hole) Brake Duct $15.00
#10 Fuel Line with Aeroquip Fittings $39.00
MSD Soft Touch Rev Limiter Boxes $35.00
MSD Single Channel Electronic Interface Box $35.00
Ovalcraft (2 hole) Aluminum Spindle Duct $20.00
Peterson Oil Filter Screens $19.00
Panhard Bar Screw Jack Adjusters $39.00
Panhard Bar Screw Jack Adjuster $9.99
Penske 7100 Series 9" Shocks $99.00
Penske 7300 Rebuild-able, Rebound Adjustable Shocks $249.00
(2) Penske 7100 Series Rebuild-able Shocks $199.00
Performance Friction Hats and Rotors $75.00
Lot of (12) Purolator 16" Air Filters $99.00
( QA1 Steel Shocks $349.00
QA1 Brand Light Weight Shock Oil $6.99
QA1 Brand Light Weight Shock Oil (11 quarts) $55.00
Remote Oil Filter Mount $49.00
Remote Oil Filter With Oil Lines $59.00
(2) Performance Friction - Scalloped Front (.125) Rotors $69.00
( 5.5" Tall Front Springs $79.00
Safety Solutions Cam Lock Belts $99.00
Complete Steering Assembly $49.00
KRC Power Steering Tank $20.00
Oval Craft Power Steering Tank and Lines $20.00
Complete Front Suspension, ARCA, K&N, IMCA Mod, Super Stock $149.00
Schroeder Racing Products Quick Disconnect for Steering Wheel $39.00
Wedge Bolt $19.00
Willans Cam Lock Safety Belts $59.00
Winters Starlite 55 Wide 5 Hub $39.00
© 2024 HoseHeadForums.com Privacy Policy
